WoW at 1680x1050
Chocobar
Getting a widescreen LCD soon and was wondering if I'd see a big difference going from a 6600 GT to an EVGA 7600 GT KO?
Currently running 1280x1024 but it drops to 38-40 FPS when in Orgrimmar with moderate to low population.
Thanks.
EDIT: Typo. 6000 GT to 6600 GT.
Getting a widescreen LCD soon and was wondering if I'd see a big difference going from a 6000 GT to an EVGA 7600 GT KO?
Thanks.
You will see a gain with a 7600gt.. but DROPS to 38-40 is still really good..
If you are unstatisified with 38-40 FPS with your current card then do not expect much when you get the Dell LCD. I run the same resolution on my 2005FPW with all settings on high and I get around 34-40 in orgimmar on a 7800GT. I get around 40-45 FPS just normally playing the game. It drops to the 30s at times, but never lower than 30. The 6600gt and 7600gt I consider to be far inferior with their 128 bit pipeline.
7600gt is still a very powerful card dispite the 128bit pipeline. plus the 6600gt doesnt need it because it only has 128mb memory.
This is pretty confusing, I don't want to buy the card and get the same performance my 6600 GT offered :confused:
i recently made the same upgrade in cards and like tripled my mark05 score
7600gt is stronger than x850xt in most cases
In the middle of Org or Ironforge pretty much every system ive ever seen drops to around ~50fps max. I think its more a coding issue.
I run at 1600x1000 2xAA with a 6800gt (which from what i gather is about equal in performance to a 7600gt) and it runs fine. It will get ~70 fps in major cities (untill I turn on all my addons and whatnot)
the 7600GT is far faster than the 6600GT, don't worry. You should have no problems getting WoW to run at 1680x1050 once you upgrade :D
7600gt is faster than 6800gt
http://www.futuremark.com/forum/showthread.php?t=164
6600 GT 128/256MB (500/900 (1000 PCIe)) (2.0/16.0) (AGP/PCIe) 128-bit
- 8 pixel shader units - 8 TMUs - 4 ROPs - 3 vertex shader units
The high core and memory (GDDR3) frequency mostly eliminates architectonical deficiencies (4 ROPs, 3 vertex shader units and 128-bit memory).
7600 GT 256MB (560/1400) (4.48/22.4) (AGP*/PCIe) 128-bit DLDVI
- 12 pixel shader units – 12 TMUs – 8 ROPs - 5 vertex shader units
It’s a bit faster than a 6800 Ultra and therefore is it natural to compare it to a 7800 GS. The X1800 GTO has a similar performance. Good overclocker.
* Only Leadtek WinFast A7600 GT TDH and XFX 7600 GT!
7800 GS 256MB (375/1200) (3.0/38.4) (AGP) 256-bit DLDVI
- 16 pixel shader units – 16 TMUs – 8 ROPs - 6 vertex shader units
This video card is a bit faster than a 6800 Ultra and the performance is equal an X800 XT PE. Games using HDR with FP blending (like Far Cry) can increase the performance gap to 50 % when compared to a 6800 Ultra. The card can’t be softmodded.
