I'm trying to find a balance with my new CPU, I havn't had a chance to have a real good play, probably won't until later in the week.
I have a new setup with a Swiftech Apex Ultra + water cooling rig and with the fans almost running at max speed and the pump running at max speed - which isn't too noisy - I can get 2.7Ghz stable on 1.53 Volts, but I think this may be too much volts for this overclock, I'm going to drop the volts down tonight and see if I can run the water cooling at a slower speed while maintaining stability. at the moment if I slow it down prime crashes.
temps are about 41 degrees Celcius which is pretty damn low, havn't checked temps at the lower speed tho, I really need to hae a good play tho, pity it takes soo long to test for stability.
