Please bear with me a bit, I'm not a well trained network engineer so I will do my best to explain my thoughs here.
So, where I live we get a free cable internet connection. From what I can tell this connection is broken down into a seperate network on each street whichs uses a highspeed connection (fractional t3) which is shared among the steets here, which I assume is about ~3Mps (from what I understand is the smallest logic breaking point for this type of connection) dedicated to each street. Each connection is capped at about 1Mps per IP on a dhcp setup.
I can easily set up three connection using three cable modems and get three machines running and serving at the regular cables speeds without creating a bottleneck. With the way the streets run, I can connect to the street I live on and also hit wireless that is broadcast from the next street over.
Now, what I want to know, can I bridge either of these connections and get a faster overall speed for a single server? Basically, I want to try and get three cable modems dedicated to incoming only and use a few of the wireless connections as outgoing only traffic.
I know there was software like this written for that dds connection where the modem worked as a uplink to control the fast download via satelite. Has anyone tried anything like this? Have any notes sitting of what worked and what didn't? I wanted to get thoughts before going and spending a bunch of cash on cable modems only to find it isn't possilbe or worth the time.
