Would this work to stop something from shorting out?
newls1
Hopefully soon I will be getting my Phase Change cooling unit back, and I just thought of this: "JUST IN CASE" a drop of condensation might drip on a pc part, could I submerge (lets say) a video card (a cheap one to test with first) in liquid wax, pull it out, let it get hard, and then put it in the computer and see if it still works? If this would work, and any drips of condensation would drip on this part, it would be totally protected right?
Well, there are two main problems with this idea. First off, if you are dipping the whole card in wax, how is the fan going to work? Fans dont like being coated in wax. Second, assuming you have a fanless heatsink on your graphics card, wax is a very poor conductor of heat, so your GPU will not be able adequately dissipate it's heat.
This sounds like a poorly thought out idea. If you properly insulate the area around the cooler, the CPU, and the back of the motherboard underneath the CPU, then condensation should not be an issue. You are much better off making sure condensation leaks do not happen rather than trying to plan for the occurence of them happening.
not only the gpu, but all the other components on the video card generate heat as well
well, as i've commented previously regarding condensation: i think that masking off pins, slots and hot-running components and then applying several layers of spray-on conformal coating to your PCBs, and then coating the pins and slots with dielectric grease prior to assembling the computer is the best method of "just in case" condensation proofing.
MG chemicals makes some pretty decent suff. i use it, and swiftech includes a can of it with their all in one pelt kit.
about $20 CDN for a can of something that was actually meant for waterproofing electronics is not such a bad investment as compared to trying a hack-job fix with wax that might or might not be viable in the long term. wax might accidently melt, in some areas, dude.
