Would this be extreme?
DFI Daishi said:
no, but modding one of these to accept the toaster that they were designed to mount in the front bezel, and still maintaining good system temps would be. http://www.antec.com/us/productDetails.php?ProdID=81600
Haha, good call m8.....I was waiting for someone to say it.
Personally I don't see the reason for this post to be here.....much better suited in Case Modding or the main Overclocking and Cooling forum.
actually, i'd like to know if setting a box fan in front of it would cool it any...b/c of the mesh front panel...
:confused: :confused:
so, how close is your case temp to room temp already?
if it's way off, the fan might help some.
more than likely, though, it'll just be a lot of noise for no usefull gain.
either way, it's not an extreme cooling solution, and i would really like to see someone do my suggested mod some day.
i just really hate how the p160 looks, though the p180 isn't nearly as bad.
Don't hate the p160.
Although I would have done the toaster mod if I had thought about it before I moved my psu to the bottom of the case.
SpoogeMonkey said:
A triple slot toaster that takes bagles and english muffins! Now that would be sweet.
And no, a box fan prolly won't help you any...do you have a 120mm fan in the front already?
that it would be. add a peltier CPU air chilling solution with integraded cold box to keep your snacks safely refrigerated, and you wouldn't need to go outside arm's reach of your box even when you want a snack.
DamienThorn said:
Someday you'll have to deal with your repressed, unrequited love of the P160. :p
love....hatred....they're sometimes pretty similar, aren't they?
