Would there be any performance improvment?
Alaska Wolf
For me, given my hardware, especially my display, running a GTX-570 instead of the HD 6950 en-route to me?
My monitor is a 52" Sammy HDTV.
Put another way, given the maximum resolution(1080p) and refresh rate the Samsung is capable of would ANY game play with higher settings and faster frame rates with one card over the other?
Also is anyone familiar with the advantages/disadvatages running "Automotion Plus" versus "Game Mode" on this set?
Alaska you have asked this in a few different threads. Can you not just accept the answers you were given in those threads?
The 6950 is a fine card and probably the best bang for buck card of the current crop of cards. And if you feel the need later on for more power you can just add another one for a very cheap performance upgrade.
Game mode is generally the best option if you are playing games on a TV as it reduces lag.
Thanks. I have kept reading reviews and they all seem to say the 6950 is OK but the 570 is Tits.
Can I run three 24" Samsungs @ 5760X1200 in Eyefinity for gaming IN ADDITION to using my HDTV for my main monitor?
And did you mean just add another 6950 in crossfire?
Yes you can, but I am not sure how this would look. Bezel size is already an issue, and I am sure the bezel of your HDTV is huge!!
Yeah I mean adding another 6950 in crossfire. So far 69xx series in crossfire is very good and seems to scale very well.
I'm sorry, I haven't explained what I meant very well.
Using these cards can I have three monitors using Eyefinity for gaming and STILL use my HDTV for my primary desktop.
Or is some kind of a switch needed?
Well the new cards can support up to 6 monitors so I guess it's possible. You can group 3 monitors together for games and have the desktop on the HDTV.
For four monitors I think you will need a display adaptor though.
I gotta tell you all, I am SO glad there is a consensus on this...:confused:
What did you expect? people have different opinions on everything.
Anyway, there should be no confusion for you, you bought the 6950, it's a very good card and any review I have seen recommends it. So you should stop second guessing your purchase because you will only drive yourself nuts.
They are both really good cards, but the 6950 will do what you want for cheaper. You see if you want to connect 3 monitors and a TV to your computer you only need one 6950 card (eyefinity) but you would need two 570's.
your not going to get one. there are always going to be fanbois on one side or another (to be nicer people that believe they have been "burned" by one company or another). I have had issues with both company's drivers and could easily slam Nvidia drivers as well as AMD. the truth is that its more a of a choice of evils then one being better then the others. actually scratch that, the real truth is that 9 out of 10 will never have an issue at all with either. and those that have issues are often not actually driver issues per say but conflicts of one kind or another. trying to make a product 100% compatible with all the thousands of types of hardware probably isn't realistic.
The 6950 is a great card for your resolution and has been explained numerous times you're not going to see much difference between the two cards at your resolution. Maybe 5% which is the difference of only a few fps with max settings.
Thanks.
Again.
I just DL Heaven. Very neat stuff.
I'm thinking of ordering a second XFX 6950.
Question, in order to cut power usage in Crossfire is it possible to set them so only one is running is you are not gaming?
Thanks.
Again.
I think it does that by default but check that.
http://hardocp.com/article/2010/12/14/amd_radeon_hd_6970_6950_video_card_review/9 said:
AMD Radeon HD 6950
If there is a real champion in this evaluation, it is the AMD Radeon HD 6950. AMD has set the MSRP at $299 for the 2GB Radeon HD 6950. 1GB models may even be cheaper. The least expensive GeForce GTX 570 is currently $349. That is a difference of $50. In all of our tests, the new Radeon HD 6950 either matched or beat the GeForce GTX 570.
The GeForce GTX 570 just got some new competition in town, and the competition is winning. For the same performance, you can save $50 and get the AMD Radeon HD 6950.
Saggy tits maybe :p
Its a grass is greener thing. With nivdia i've had just as many problems with drivers as i've had with ati cards.
What I like about AMD is that they put out monthly drivers and sometimes multiple hot fixes. So sometimes i only have ot wait a month for a fix. With nvidia sometimes it be months before nvidia released a non beta driver
