Hi, I have a Cooler Master Cavalier case which has one 80mm lower intake fan on the front and a 120mm outtake on the back. I have added an 80mm side fan for cpu exhaust and have a Scythe Kama Bay installed in my drive slots. For CPU cooling I have a Scythe Ninja w/ 120mm fan blowing towards my back outtake. My CPU is a a64 3700 oc'd to 2.86 and temps are around 35-37 idle and I've seen it load as high as 47. I also have a Zalman gpu cooler on my 7900gt (at stock speeds). Under the gpu I have a pci slot exhaust blower . With all that in mind, I was wanting to mod my case a little and was thinking that perhaps a 120mm blowhole intake on the bottom of my case under my chipset (as that seems to be the hottest part of my case as the harddrives block most of the 80mm front intake) might help, as well as a topside 120mm exhaust. What I was wondering though is if it would make any difference as I think my temps are already pretty low, considering the ridiculous heat wave Texas is having. Also, would the bottom to top airflow conflict with the front to back? My wiring is decent and I don't think it impedes any airflow. Any suggestions or advice would be appreciated, thanks!
