Would I Really Notice The Difference - 12ms or 25ms?
The provided response ratings are pretty much worthless for direct comparisons, as they usually only are an indication of the best-case performance. There's a huge difference between grey-to-grey and white-to-black when it comes to the response ratings.
I'd only rely on reviews by independent reviewers and, if possible, by using the monitor myself.
usually the manufacturer's ratings are too good to be true......but, if they were true, you would definately notice the difference. 25ms lcds ghost like crazy, and 12ms don't ghost nearly as bad.
However, there are always exceptions. Basically, try to read up on as many different reviews as possible.
Analog to Digital converters have come a long way since the first lcds too. You might be happier with a faster response time, and d-sub, than with dvi & slow response time.
I have dvi at work, and d-sub at home, and I honestly can't tell the difference between the two. Text is super crisp, and colors don't bleed.
Most big name brands response time will be correct. But for something like that ag whatever brand i doubt its correct.
OK thanks, well I've read loads of reviews on the AG Neovo - all saying it's very good, but I don't like the look of it to be honest!
It just seems a bit of a waste having a DVI graphics card without using DVI though.
I actually agree with you on the DVI part. I tested both the VGA and DVI connection on my new ViewSonic VP930b and was able to see a clear, albeit not huge, difference between the two. At the store you linked to, the bext monitor there was the Samsung 913 IMHO, but it was solely VGA. I'd shop around a bit more if I were you. BTW, is it much more expensive to order from elsewhere in Europe?
Albert
