Would i need another rad?
Nick_Leo
For xmas i plan on water cooling my 8800gts and my northbridge, would my black ice gt 240 stealth be able to handle the heat or should i invest in another 120 single rad? Also will my db-1 be able to pump all of that?
If your Stealth 240 is already used for cooling your CPU, then it's not really sufficient. You can get with a sing 240 for the CPU + NB and a extra 120-240 for the GPU. A easier way would be to get a 360 like a Swiftech MCR320.
This is correct
well my cpu is already watercooled so thats prob y i forgot to put it in, it also says in my sig e6850 4.0ghz on water.
Figured as much, but I don't like to make assumptions when my ass could be held on the line ;).
Get at least another single radiator in the loop... Another double would be ideal.
That's why I looked at the sig and noticed the CPU is cooled. I made a opposite assumption and I was right (assumptions is a crapshoot anyway with no sufficient infos ;)).
