Would appreciate GPU upgrade suggestions!
Nearsite
Hi Guys - my current rig in my sig. Looking to upgrade my graphics card to either a 1070ti or 2070. I actually run two monitors, the other (not in my sig is a Dell 1080P IPS display).
I play games like Diablo, Heroes of the Storm, Slay the Spire, and all manner of ARPG. I would like to play Classic WoW and Red Dead Redemption 2 as well.
I don't want to get a 1080, because it appears to be in the same price range as a 2070. What do you guys suggest? Thanks in advance for your time.
What os you running ?
I was just going through this same problem.... advice was to get the 1070 ti , since I'm still on
windows 7...
Got a new evga 1070 ti ftw ultra silent a couple of days ago for $400 .. running through benches
and doing good so far.
Also I'm still using 1080p monitor, so if you have 2 monitors and game on the 2k one , and
run window 10 I think I'd try a 2070....
If I were already spending $400 on a 1070ti, I would just spend the extra $100 and get the newer tech 2070. That said if your budget only allows for the 1070ti it is still a solid performer.
I currently have a 1080 (pretty much same performance as 1070ti) and it does great for me @ 1440p.
Thanks guys, I use Windows 10 and I'm leaning towards what you guys are suggesting - RTX 2070
I would be very skeptical buying any RTX cards now, since they have so many issues.
Used 1080 ti is the best price/performance value right now if you're looking at the high end.
I've bought and sold many parts on ebay, for the most part it's been solid.
You can also check the for sale section on this forum.
