Would adding a GPU block to this system viable?
troisanh
Planning on new watercooling setup consisting of:
d-tek fusion cpu block
maze4 chipset block
pa 120.2 rad+2 fans (med yate loon fans)
DD d-5 pump
t-line + DD fillport
1/2 ID tubing
My only question is would adding a GPU block for 7900gtx be pushing it, wanting to OC to 3.6. Case will be modded LL65b. Comments would be appreciated.
It'll be fine. I was running an X2 3800+ and a 7950GT on a similar setup with no ill effects.
dont see why not, it would increase the overall water temp a few degrees but the D5 can definately handle the extra load, and that radiator should be able to as well.
