Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Would a 550w antec power supply be sufficient enough to run a geforce 5950 ultra video card and everything else?...if not then could anyone suggest anything better plz..thx
I run two optical drives, two hard drives, a "9700 pro" (actually a softmodded 9500NP), an Athlon XP2000+ @ 2300MHz, and a bunch of other stuff off an Antec SL350 power supply.
I brought a DC current probe home from work just for kicks, and everything falls easily within it's ratings. There's no need to buy a 500W supply, IMO...
you run that probe at spinup?
any way to log it? That would be nice
if you could
but there will likely be no problem being over powered either
might effect the efficency would be all,
and that would potentially create more heat (less efficient)
