Would a dual Opteron setup be practical for me?
Hi, firstly I would like to address that I have always wanted to build and own a multiprocessor system. That is half the reason why I posted this; I just need the other half to be critiqued! I am a pretty hardcore computer user, but not extreme. Among the most CPU intensive (to my knowledge) programs I run are three distributive computing projects (SETI@Home, Einstein@Home, and Folding@Home), Fritz8 (computer chess engine), Adobe Premier, and Adobe Photoshop. Also, money isn’t really my MAIN qualm here. Really I want to know if I’m wasting the money I’m spending; if the spending is rightly justified, I have no problem dishing it out. This is why I work two jobs! ;)
Sincerely,
cc
Really depends how often you do all of those things you mentioned, and how many at once. A A64 would handle them well, but if you feel you are a real power user you'd be set with a pair of 246's. Just remember not to have too much overkill, otherwise its a waste of money.
IMO you should stick with single CPU, unless you feel you really need to step over to 2 CPUs.
If I was to go single 64, would my harddrives be my bottle neck?
Which processor would you suggest for the aforementioned program load?
Which mobo would you suggest to accompany that sweet 64?
I'm pretty sure that HD use is relatively insignificant for most distributed computing apps. Photoshop depending on what you do with it may get a sizable advantadge from a dual-processor workstation, but it's a case where you probably already know if you need that.
Mobo there's several things to factor in, PCI-E or AGP, do you need PCI-X slots, are you planning to use ECC memory...that kind of thing. Hit Newegg and find a few that look nice to you as far as the price/features, and go from there.
For folding, etc. if you want to stack up the work units, you're better just building a cluster of cheap single proc rigs. Maybe some cheap $60 mATX basic Athlon boards and OC'ed mobile XPs w/ just as much ram as the distributed computing app wants. Run Linux and boot them off the network so you don't have to mess with (or spend money on) putting drives on them.
Now for Photoshop a dual Opteron is quite nice. I saw a dual G5 2.0 vs. dual Opteron 246 (2.0) review on some Mac site. The Mac won all thier graphics program I haven't ever heard of tests but the Opteron pulled through on the Photoshop test.
So basically you'll be building one kick-ass Photoshop box.
Just remember the bill's going to get big fast & figuring out what card to put where can be complicated and difficult when you have 3 different kinds of PCI slot in your system. I had to replace my sound card & swap my TV card for a USB 2.0 TV tuner when I upgraded from a dual Athlon MP system.
Remember folks A64 run in 32-bit mode when you haven't configured a 64-bit kernel. Quit talking about them as if they are 'better' somehow.
As far as distributed processing goes, it's just that 'processing'. It's just math so go with big numbers. Same as video encoding.
The only things that need anything else these days are games, Windows operating systems, and GUI's.
Opteron's are pricey, why would you spend so much?
Practical?
Probably not
Bragging rights?
Definitly
A waste?
You decide, it's your money
