Hey everyone
I have a Frankenstein of a machine that I use as a loaner when working on others computers, my video encoding rig, and secondary Hyper-V lab environment that I boot into Server 2012 R2 when I need more resources than my primary lab can muster
Here are the current specs:
AMD Phenom II X6 1055T (2.8GHz, 95W TDP)
Coolermaster Hyper T2 Cooler
Gigabyte 970A-D3P Rev. 2.0 latest BIOS
32GB Kingston Hyper-X 1600MHz DDR3 (Running at 1333 due to IMC limitations in the CPU)
Gigabyte 750Ti 2GB OC
Corsair RM650 Modular PSU
120GB Samsung Evo 840
250GB Samsung Evo 840
1TB Seagate Desktop Drive SATA3
Case: A 13 year old white ATX case with a front/rear 92mm fan. I found the case brand new in box last year and as it was the first case I ever built a rig in many moons ago I had to build a more modern thing in it. Video card length is an issue as is cooling which is why I am keeping CPU's below 100W TDP.
Is it worth going up to an FX-8320E? It is around $180CAD (I am in Canada) and is the last upgrade that I can do to this. As I noted my goal is to keep the TDP below 100 watts as the case environment is a bit tight.
