Worth the upgrade?
Jay_2
I have a 37" 720P/1080i 37" LCD TV (Toshiba) I am wondering for bluray playback if it will really be worth upgrading to a 42" 1080P set?
If you have the budget, then I think it would be a worthy upgrade.
More importantly, the extra 5 inches will definately be noticed, though the native 1080p display over the semi-1080i on the bluray should give you a very decent visual improvement all depending on the set.
