Worth the money?
(sic)
I'm using the Corsair HS1A1 with a Asus P8P67 Pro MB.
This rig is used for gaming.
Would it be worth upgrading to a standalone sound card?
If so, any recommendations? Budget...let's say $100-$150?
I'm not necessarily having sound issues, but just wondering if I'd see a decent improvement with an upgrade...
Thanks
Why not just HS1, or Vengeance 1500 if you're feeling like a baller?
Well I've already purchased the HS1A. Would I see big improvements with the Vengeance 1500?
Say I went with the Xonar DG... Would I hear a noticeable improvement? I not looking to spend even $20 if I won't see a decent amount of improvement.
Yes, better sound quality than onboard plus support for Dolby Headphone, which is a huge benefit for gaming. Easy decision to make for $20-30.
Plus it is usb so no more sound card to bother with.
I prefer regular headphones personally but I would go for the usb if I was on a budget and wanted to keep it simple.
