deadman_uk
- Jun 30, 2003
Hi, is it worth overclocking my already pre-overclocked eVGA GeForce 7900GT CO? (Take into consideration that I will remain using the stock cooling)
Are we talking a few Mhz on the overclock here?.....or over a hundred?Faction said:overclocking rarely leads to much more than 5 more fps.
Faction said:overclocking rarely leads to much more than 5 more fps (excluding those who unlock more pipes, etc). No it is not worth the hassle.
deadman_uk said:Then how much should I overclock? Whats the maximum temperature I should hit? At the moment my card is 47C.
How much should I overclock up to? I am at 500Mhz core clock and 1500mhz memory clock (stock settings). What should I increase it to?
Im sorry, whats a volt mod?MrFace said:Do a volt mod. My core is around 620. Not sure what my memory is at, I think around 1650.
No, I dont like the idea of touching the actual hardware. I will stick to software overclocking via the control panel only lol. If anyone could answer the above questions, that would be great.TheGoat Eater said:With a simple vmod - conductive pen trace - and a Zalman VF900 I got my 7900GT to 700/800 <-that I am selling because I got a 8800GTS. If you are hesitant I wouldn't try a vmod unless you know what you are doing and read up on it for a long time to get a good idea of the mod. Its easy and works great but if you do it get some auto masking tape and an exacto knife and mask the area off with tape so you don't F*ck up with the pen's ink. best of all you can remove the mod with some mineral spirits if you make a mistake or want to undo it. you will need a multi-meter.
Ignore it and just run it at 550/1580. Then test with 3DMark06 and some games.deadman_uk said:Sigh... the control panel only lets me go up to 541Mhz on the core and 1.58GHz on the memory, any higher and it says the test has failed. How come?
I cant do that. If I apply it or OK it, then it says it cant apply these settings until you have clicked the test button. When I click on the test button, it says the test failed. So I cant think of how I can bypass this.dark_reign said:Ignore it and just run it at 550/1580. Then test with 3DMark06 and some games.
