Santa Claus
- Nov 10, 2008
Hi, is it worth the hassle to log changes in smart-values for a long time?
What i want to accomplish with this is to be notified of any problem before the harddrive fails so i can make backup's of important data.
Log smart-values so i can see what have changed over several months of use.
But there are several problems with this and im not thinkin about the difficulty with predicting a failure.
Software can report different values for the same harddrive, threshold can be set from factory way beoynd logic and different brands handles smart differently.
So the main quetion is, is it worth the problem to log the values?
Which program would work best?
How much can smart-values be trusted?
Write your own questions, perhap even with an answer
The harddrive i want to log is a 4day old WD6400AKS, but if its works good i will also log the harddrives in my backup computer, 2seagate 1hitachi 1ibm and 1wd.
Regards
Regards
