Worth going from CRT to LCD
Finsta
I have a Viewsonic A90F+ and am satisfied with it. Is it worth upgrading to a LCD?
I just upgraded from a Samsung 19" 900NF to a Dell 2001fp LCD.
Do I think its worth the upgrade....YEP. Especially if you can sell your CRT so the price isn't so bad. But taking price out of the issue (afterall if you can't afford an LCD...then you can't afford an LCD...simple as that), it was a VERY nice upgrade for me.
The image is SOOOO much crisper and less blurry. I had both a 2001fp hooked up at the same time as my Samsung 900NF and I was quite shocked at the difference.
Yes...people will argue that LCD's are perfect and yes they do have drawbacks...but for me the drawbacks are FAR outweighed by the advantages over CRT.
As long as you get a decent LCD with good refresh time and you're not a gamer playing 15+ hours a week, I would definitely reccomend the upgrade!
I say yes it is worth switching. My gaming room does not heat up anymore. I replaced 3 crt to 3 LCD's and my electricity bill dropped like $10 dollars a month. Plus my text and screen colors looked so much better.
I say go for it if you have the extra cash.
For me, it was a pretty dramatic change as I was running a 17" Sony 210GS (trinitron) and switched to the almost-ubiquitous 2001FP. In a word, err...acronym: OMG. :eek:
I didn't need glasses, I just needed this LCD!
The only gripe I have about LCDs is the black level. They can't even come close to a CRT on that front, but every other aspect is superior and I'm happy with change.
Yes, i think you will want to do it. I did, after many CRTS of all kinds
over the years. Now i will never have anything but an LCD in the future.
I'm going to agree with everyone here.
My LCD is superior in image and color quailty to my old CRT.
I think that getting one with DVI will ensure video quailty. It may be tough tp properly calibrate one to use the VGA input.
No, keep your CRT. CRTs support higher resolution, last 3 times longer, cost 3 times cheaper, and are better for gaming. The only lcds worth buying cost like $800+. If you dont want to spend 800+, keep your crt.
Originally posted by Finsta
I do alot of gaming so I am confused. I am getting mixed results.
How much gaming? I play games about 6-8 hours a week tops. I don't notice ANY ghosting (but I'm not necessarily a hardcore gamer at 6 hours a week). However, one thing I did notice is when you move the screen at a medium speed (such as in a fps game) everything becomes a little blurrier than a CRT. Of course as soon as the motion relatively stops the screen instantly clears up. So I guess this might be a form of ghosting???
Anyways, while this part is inferior to a CRT, it doesn't bother me. Especially with how bright and vibrant the game looks. Its just a trade-off. I'd say that a CRT only has a small disadvantage in gaming. For everything else, an LCD is the complete way to go. But then again, even in gaming...its all pros and cons. Just depends what bugs you more... For instance, like I mentioned above, the screen becomes a little more blurry with an lcd for "medium" speed movement. But with changing resolutions, the picture always fills the screen with an LCD. I hated my CRT because I would have to run games at different resolutions for best performance and anything other than my normal desktop resolution throws the whole freaking picture off. And I'm not gonna adjust my monitor settings just to play a game...
I don't think you're gonna find a definite answer here because there is NO clear answer. I just know from what I've read and seen MOST "average" computer users that go LCD say they'd never go back. This includes myself. I threw out two aperture grille 19" CRT's for two Dell 2001fp's:) and I'd never go back.
If you use your computer for gaming 50%+ of the time...I'd hesitate to recommend an LCD to you without you checking one out for yourself...at which point you could still go either way depending on personal preference. But if you're an "average" gamer playing maybe 6-12 hours a week then I think theres a good chance you'd like an LCD better because most people that fit into this "category" of computer user seems to like LCD's A LOT better.
Long rant....sorry...but I had the same exact worry before I made the LCD jump about 3 weeks ago.
I'm still pretty heavy in the CRT camp.
When you can get an "off-lease" perfectflat Trinitron 21" that will do 2048x1536 @ 80 hz for less than $300Cdn shipped I see no reason to use an overpriced LCD, especially if you like uber-high resolutions.
If the electricity Jiggawatt/hour is expensive where you are (like California) then an LCD does have an advantage. Ditto for heat output (if you live in Texas or Mexico) or if you don't have a good solid desk or a lot of room.
But I'm not one of those people. Up here in Canada, we often turn "on" copper electric heaters to keep warm, so we might as well use the electricity in something useful like a monitor or SETI/Folding crunching. I also have a dual Desk (which two 21" CRTS sit on) and a smaller desk in front which sports several sets of keyboards and mice.
As for quality... There are a lot of crappy LCD's out there, too many for my liking. There are occasional standouts, but they are rare... Me, I'll hold out for a plasma based monitor.
Amen, I am a Canuck.(Quebec) Although, I am confused because some have told me go, get one, some have told me LCDs have better Image Quality then CRTs, and others wait or don't get one.
If you game a lot and have none of the reasons I mentioned above to switch I'd say stick with the CRT.
Trintron CRT's are very high visual quality but tend to burn out a little quicker than a normal CRT (a normal CRT might last 6 years, a Trinitron may only last 4 with constant use)
LCD's have their own problems, there have not been any real long term studies done on the new LCD's but old LCD's do annoyingly tend to eventually get "pixel-death" either from a burnt out pixel, a pixel that refuses to change colour, or even sometimes the pixel refresh slows down (as the elements in the screen slowly degrade with time)
You can't even use the slightest pressure on an LCD screen or you risk future pixel-death damage. Its highly underplayed by LCD makers, but it does happen.
I'm going to have to stick with the CRT decision, as long as you have the desk apce IMO you should be going with a CRT. For any details why... see everyone else posts, I'm getting tired :p
As long as you do not care about deskspace, stick with the CRT, if you are unhappy then move to LCD. If it ain't broke why fix it.
Coming from a hardcore gamer on a 1800FP (I play 4-5 hours a night) it completely depends on your eyes. To me I cannot see any ghosting on this monitor and it is a 25ms monitor, so as long as you go 16ms im sure there is no problem with ghosting. As for everything else (web browsing, movies, etc) LCD is definately superior to CRT in almost every way.
Well think about this. People that get an LCD would never go back to a CRT. But people that haven't bought an LCD either can't afford it or justify it otherwise. But the bottom line is if you got an LCD you would never want a CRT again ;)
Ohh btw plamsa screens still suck total ass! My buddy has one that is just over a year old and its already starting to show wear, definately blurrier on Xbox games. Now for a $4k investment thats terrible.
I just made a new thread " Does monitor quality deteriorate with time?", and then saw your 3 day old thread pop up above mine. Read it, and I see that just about all the replies confirm what I must be seeing in the difference between a CRT and a LCD. Either my Trinitron CRT is just old, or those who swear by CRTs have different vision than I do. I couldn't agree more with the statement, "once you get an LCD you'll never want to go back". Hands down, my 2001fp has an absolutely beautiful screen. It's like finally getting a pair of eye glasses after needing them for years.
I've owned several CRTs and LCDs. I was turned off by the 1901fp and 1900fp because of the ghosting. I was an avid Q3 player and I noticed the ghosting and it was to significant for me to tolerate. However, everything else about the LCDs dominated the CRTs I've owned. I even spent 650 on a brand new NEC 2141 as was recommended by most here. Sure, the 2141 could do uber high resolutions but what difference does it make when nothing is readable? Even at 1600x1200 the picture seemed blurry (and this is off of a 9800 pro). I came to the conclusion that the LCDs I had owned and sent back had spoiled me and that I'd never be able to live with a CRT again.
After the 2141 went back because of its blurry picture and geometry problems, these CRTs aren't really "flat" and often have geometric distortions, Dell released the 2001fp. I ordered one and do not see any ghosting. This is coming from a gamer who returned the 1901fp and 1900fp due to ghosting. After using this 2001fp for a few months now I couldn't be more satisfied.
My main reason for upgrading I couldn't stand the edge of a CRT not being straight. Even the most expensive would have some distortion along the edge of the screen.
BigDHO1, you say your an avid q3 player so you would know that framerate is king on that game.
could you tell us what frames you are getting on your 2001fp?
Just to interject here.
Anand just did a review of the new Samsung, which seems to overtake the one big complaint that people have with the Dell, the black level.
http://www.anandtech.com/showdoc.html?i=1974&p=7
Now... Black level is not a big problem when gaming, as most games are too dark to start with, but for other stuff it can be a problem. Anand specifically comments the new Samsung is much better at colour and black reproduction, but still has problems with blues.
I've had this NEC 1760NX for about a month now and love it. The room is cooler and I can see my desk again for the first time since I assembled it. I will never go back to a CRT again after having been worried about ghosting and dead pixels. I have no dead pixels and the ghosting is so slight that I don't notice it because I more focused on winning the game to focus on how the game looks.
Just learned about Windows built in ClearType...and OMG, I love this LCD even more now.
As for the costs, LCDs generally cost twice as much and last about 5-7 years. During the first 3-4 years, the extra cost will be nullified in the money saved from using a 40w LCD instead of a 130w CRT. That leaves what to do in 5-7 years. My answer...the same thing I did with a CRT...buy a new one that has much better technology. The costs will basically even out as more money is paid up front for and LCD, but a CRT costs more to operate each year thereafter.
No regrets here...and by the time I get my next one in a couple of years...I doubt this arguement will still exist...if CRTs even exist at that time.
Its kind of like the forgotten argument of "do I stay with my 256 color monitor or pay twice as much for one that has 16 million colors?" Back then it was, "why do I need more than 256 colors?"
If your going to game dont get an lcd please. Lcd's are terrible even if you spend a couple grand.
I play about 4 hours of cs a day (fps game) and all lcd monitors are terrible on them.
If your going to do any gaming please get a crt
I was curious 'cause I am stuck with this A90f+ and it is not really worthwhile to have 1600*1200 @ 65hz max. Also, the new technologies like OLEDs are coming out so I am not sure. Plus, I am not the richest person on the block so I want to know if it is worth what money I have to spend on this if I do have.
I don't get a framerate as framerate is not dependant on a monitor that doesn't refresh. A top of the line CRT at medium resolution will have a max refresh rate of what, 120Hz? That means the monitor refreshes the screen 120 times a second. That's regardless of what you get on your super-uber-l33t 54000xt pro xtreme video card. This is what causes old games like Q3 to tear, as the monitor cannot keep up with the video card. People like to get high frame rates to brag and because it means that even in high intensity fighting your FPS will not drop below a certain amount. Also, and this only applies to Q3, I saw a study about how your FPS actually affects the physics of Q3. People who had high FPS were actually able to jump farther and move faster. This was a glitch and I'm not sure if it's ever been removed. I think they tried with PR 1.25 but everyone hated it. IIRC, you moved the fastest with a framerate of a certain multiple but I forgot what that number was.
Now to LCDs. LCDs don't refresh because the pixels are always on. No offense to you, but I'm awfully tired of explaining this to people. This is a 16ms screen so if the action on the screen was just causing a certain pixel to go black-white-black then it could do that 62.5 times per second. However, most action isn't like this. Take CTF2 for example. If you are on the red team and in the middle then there are lots of different shades of red. Moving from one shade of red to another probably takes less time than black-white-black so it may be able to do that at 80 or 90 fps. If I was completely still then the pixels aren't changing at all so I would be getting an infinite FPS. How's that for bragging? On some maps like w5 where there are lots of greys I might have a response time higher than 16ms so I might only be getting 50 fps on THOSE particular pixels that are changing from one shade of grey to another. So on any given scene I'm getting a variety of frame rates ranging from infinite to 50 fps. I'm actually quite used to how it plays now and it hasn't affected my performance. The game sure looks a hell of a lot better though.
Have you tried the 2001fp or any other 16ms screen? Just curious. By the way, the 2001fp can be had for 750 when it goes on sale which is only 100 more than the NEC 2141 which is supposed to be a really nice CRT. IMO, the 2001fp destroys the 2141 in image quality, geometry, color, clarity, brightness, sharpness, energy use, heat production, footprint, weight. Bottom line: I even enjoy gaming more on my 2001fp than I did on the 2141.
Definately agree, even gaming I enjoy the LCD more. I think its easier on the eyes too. I used to get headaches after long hours on the Samsung and the Sony 19 CRT's. I can't remember the last time I got bad eye fatigue. I can't find any reason to own a CRT anymore if you can afford even a decent $400 17".
Wow, there is a lot of debate here, continue please. I am making myself a decision from this.
The best way for you to decide is to go see lcd displays in a store and compare them to the crt displays.
Yeah, but there is one thing though. You cannot see a Dell LCD instore. Which most people recomend is the Dell 2001FP
Order it and try it out. They have an excellent return policy, no questions asked. I ordered a 1901fp from them just to try it out. I didn't like the ghosting so I sent it back and got a full refund. No big deal.
Yes...as the poster just above me said...I'd just buy the 2001fp (assuming you have the cash). If you don't like it...send it back. But I almost guarantee that you won't even have the thought of returning it...:D
This has been a fairly informative and very interesting thread thus far as I myself have been looking to make the switch to an LCD. Granted, I'm not in the same position as a lot of CRT owners out there today. I've been stuck on a 17" CRT for the longest time now.....and I swear the screen is getting smaller. ;)
The only LCD I've really been drooling over lately is still the NEC 1760NX and I finally found a Canadian retailer (online) that sells 'em.
I'm not what you'd call a HARDCORE gamer at all, I'd say I play games maybe 2-4 hours per day.....sometimes not at all. I'm far more interested in an LCD because of all the other gains they have over CRT displays.....including the crispness and clarity reported time and time again around here.
It sounds like that 2001FP is shaping up to be a very decent "little" screen but if one were to ignore it.....the 1760NX has been repeatedly reviewed to be the best "gamers LCD" around, and that's what caught my eye first. I've seen my fair share of bad LCD's and horrible ghosters so when I started seeing all these uber positive reviews on "my LCD" I was overjoyed.
Even if there was to be a TINY amount of ghosting (barely noticeable at all) I probly wouldn't even notice it 'cus my eyes aren't the most sensitive things around. Hell, I can't even tell the difference between 60Hz and 85Hz on my 17" CRT.....I think I could get away with a VERY SMALL amount of blur. :p
All in all I think it'd be MORE then worth it for myself to make the switch but what do you guys think? Did I miss anything?
Where do you get off coming through with a comment like that??? Have you even tried any of the nice LCD screens that there ARE out there??? I'd have to say no by the sound of it. Plz get off your high horse and do a little looking around and factual research before you make a blatently obvious, ignorant statement like that.....you're not convincing anyone without anything to back yourself up.
It's posts like that that can make people jump to conclusions and make a bad choice later on.....and I'm hoping to see fewer and fewer of these as time goes on. After all, we want our forums to seem credible don't we???
Here's a nice little test you can do to see how much ghosting an LCD has.
1. Boot up good old solitaire.
2. Make sure you have outline dragging turned off.
3. Press F2 until you see a face card.
4. Grab the face card and _smoothly_ slide it from side-to-side down in the green area.
You should see a light green trail following the left and right edge of the card. You will also see the outline of J, Q or K. This is ghosting.
You won't see this effect on a CRT. Not at all!
You may also notice that the pattern on the face card gets blurry. Again, this does not happen on a CRT.
I tried this out on about 20 LCDs last night a Fry's. I was pretty dissappointed at what I saw. I know there are better LCDs out there, so YMMV.
I think this is a good test because it takes the CPU and GPU speed out of the equation. And every PC has solitaire.
I might have to give that a try tomorrow at work. We don't really have any nice LCD's at Futureshop :( but oh well.....it's worth a shot. :p
As an avid gamer I wouldnt be caught dead with a LCD. The gameplay experience on a CRT smacks that of an LCD. I typically win most of my CS/UT2004 rounds on my CRT but I have noticed a severe drop in my gaming performance while playing on even high priced LCDs. They just aren't as good.
nope... I just upgraded and it sucks, and I was using a 5-6 year old ViewSonic PT770 monitor.
Things are more pixelated, I especially around text, images. Movies are the worst. I can see each individual pixel, even though I'm running at the max and native resolution. On my CRT, everything was smooth and clear... looked more like "real life". You couldn't make out pixels and things were more blended in.
