Hi Tech Guru's,
I am in need of your assistance once again...
Had this build (see sig) for a while now, and it has served me extremely well, but since I have moved into an apartment with steam heaters, the temps in here get pretty warm, and that small change has caused me some headaches in the cooling realm of my PC.
Currently getting lock ups on all high end games due to CPU temps popping up to 60 C.
Right now I am idle at 41 C.
With the case side off it never locks up and the load stays at about 52 C, and idles on 35 C.
Really want to make my rig last another couple years... its still fast, runs all new games great so far, so not looking to buy the next best thing till this hits rock bottom.
I bought that thermaltake SL1 PCI cooler yesterday and well I think it dropped me about 2 degrees, big whoop right, for 20 bucks... oh well...
moving along...
Thought it might be wise to purchase some case fans to replace the existing antec tri-cool fans. I know these fans are great, and do move a good amount of air, but as you can see I must be having some sort of circulation issues when my temps are moving up and down 10+ with my case side off/on...
side note- the exhaust fan on the back doesn't feel like its doing much until the case side is off, which can only mean there isn't enough air getting in the case?
FAN REPLACEMENT?
Thinking about grabbing 3X Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
FAN PLACEMENT- Antec 182
Intake- Front panel 1X the other spot is full of HD ^_^.
Exhaust- Top/Back 1X
Top Fan? Would this be exhaust or intake? I can't seem to find any test to prove what option would be the best solution.
Maybe I am going about cooling this case all wrong? Does anyone have the same case that has found a solution?
Off subject, but I was on newegg shopping for the fans and noticed they have my RAM still on there for $82.00 for another 2GB. Should I be going for 4GB at this point? I believe I read somewhere this boars RAM controller doesn't like 4 sticks? Was that just for XP/Visat? I am moving to Windows 7 Ultimate x64 soon.
any input is much appreciated.
moving along...
FAN REPLACEMENT?
