that would be my rig i think. i get lazy sometimes and my case is small. it used to be a beige case and i've grown fond of it for some stupid reason. maybe i just don't want to part with the $100 for a new case.
not bad eh? the case is a tad cramped for an sli system. opteron 165 and two 7900 gto's. the mobo is an asus a8n32-sli. had a little problem with the mobo overheating this weekend. those two gto's were dumping a lot of heat onto the southbridge and thanks to the heatpipe it was actually warming up the northbridge since it can't handle all that heat. so i came up with a ghetto solution.
i think that says it all...can't fit 120mm fans in there, case is too small
yeah its got a bit of noise. i want to watercool one day. would you believe that fan behind the cards dropped my mobo temp by about 18ºC?? i was amazed.
mmmm....ghetto box
mmmm....ghetto lights
theres my desk. its ghetto too, old table i got from god knows where. oh and thats my 4th samsung 226bw now. i keep getting frickin dead pixels! ah well thats future shop's problem now. i've now had all three panels, the S, C and that ones an A - which is surprisingly good from all the bad rap it gets. i can't tell the difference between it and the S.
don't ask me why i made this thread, i just felt like showing how little i care about the wiring lol. i think i'll get a modular psu next time.
mmmm....ghetto box
