Worried about new build temps
MatiasMGS
Hi, a while ago I bought new psu, mobo, cpu and ram for my pc. The case is a bad generic one with only one fan at the back. Everything is at stock speeds. At around an hour of gaming, all the temperatures run pretty high, I think. I'll attach some cpu id hardware monitor screenshots, so you'll see if it's normal or not. The video card might be hot because I've never cleaned it properly since I bought it 4 years ago, but what about the rest? PC at sig.
Stock cooler on the CPU? If yes, then all is fine. If no, then I'd reseat the cpu cooler with fresh paste.
Those GPU temps look normal to me.
Intel SB CPUs and AMD GPUs are good up to 100 C. Fans on CPUs and GPUs are geared towards silence rather than keeping things cool, so during high loads, they'll be near their thermal threshold with the benefit of things being quieter.
Amazing that the video card can run at normal speeds after 4 years of dust gathering. The thing is I can't clean it because I don't have an air compressor, and when I tried to take out the heatsink/fan out of the board, a lot of cables were plugged in, so I didn't want to ruin anything and I ended up without cleaning it. And not much can be done cleaning from the outside without an air compressor. Anyone who has cleaned my card (or similar) before?
And yes, I have the stock cooler.
Just unplug them. Each connector is designed such that the only way you can plug in something wrong is if you brute force it, with the exception of motherboard header pins. You don't need to worry about plugging in power cables wrong.
Those temps are fine. I hit temps of 65-75c on my GPUs without any problems and your CPU is running at avg temps.
Thanks for the answers. I think I got nervous because the CPU I've been using before (AMD Phenom 8450) functions at a very lower temperature rate, like 21c at idle and a max of 42c after a couple of hours of gaming...
That is due to AMD and Intel measuring their temperatures differently. Also, AMD has a max temp of ~70 C before auto-throttling, while SB processors do that at 100 C.
Ok, I know I sound dumb but I can't unscrew these screws off my video card. They are extremely tight. Any advice? :D
Carefully with a non conductive latex glove on your hand apply pressure to metal bracket arm while loosening screw. Be gentle to avoid stripping it.
with little screws like that i've found that buying a decent precision screwdriver set helps alot.
I was trying to take my aspireone netbook apart and the screws wouldn't move with a rather poor precision screwdriver i had before..
I went to radioshack and got a new screwdriver set and the screws where quite easy to remove indeed using the new screwdriver.
http://www.radioshack.com/product/index.jsp?productId=13201071
this is the set i got and it has worked well with this kinda stuff for me.
temps in OP would not warrant a second glance here...maybe I am hard on the ware
No matter how much pressure I apply to the metal bracket, I cannot move the screw whatsoever, like it´s glued or something. Anyway, you guys think it´s not worth cleaning it?
You don't need to remove the heat sink to clean it, just blow it out with air.
