World Record: Wireless Data Transmission at 100Gbps
HardOCP News
[H] News
A team of scientists in Germany have set a world record for transmitting 100 gigabits of data per second over a distance of 20M in the lab. :eek:
In their record experiment, 100 gigabits of data per second were transmitted at a frequency of 237.5 GHz over a distance of 20 m in the laboratory. In previous field experiments under the “Millilink” project funded by the BMBF, rates of 40 gigabits per second and transmission distances of more than 1 km were reached. For their latest world record, the scientists applied a photonic method to generate the radio signals at the transmitter. After radio transmission, fully integrated electronic circuits were used in the receiver.
RIAA better get on these fellers quick.
That's a ton of CDs and movies!
Lol, but a seriously large amount of data. Really impressive. When will this spill over to the 'real world?'
When you can do it over distances longer then .2 inches and have enough r&d being it to where you don't need to spend a trillion dollars setting it up.
I know the metric system is tricky, but 2 metres does not equal 0.2 inches :p
~787 inches, but I guess you were pretty close there....:D
Been a long time since school, but ...
As freq goes up, it's ability to go through objects diminishes. Not sure what 237ghz can penetrate, but it will certainly bounce off objects. That's RADAR freq, which is designed to bounce.
If you have Line Of Sight, then the obvious choice is LASER, which runs at 100 to 100,000 times that speed.
Unfortunately when the lab's neighbor turned on his 10GB router the transmission rate dropped to 128K.
Yeah, let's see them cook a frozen burrito in the microwave and pull that off ...
I actually would expect that to not be a problem, given the transmission frequency was 237.5 Ghz and aren't microwave ovens in the 1-3 Ghz range?
Yes.
It was joke for those of us who lose our internet when the microwave is running.
As far as I'm aware, there is no simple relationship between frequency and penetration, as you go through the electromagnetic spectrum, the mechanism for penetration changes. As someone from a random google search points out:
microwaves penetrate glass very easily, but they are strongly absorbed by water. Move up to slightly higher frequency, and infrared is strongly absorbed by both glass and water. Both substances transmit visible light. Ultraviolet is stopped by glass, but not so readily by water. So it's not a simple correlation between transmittance and wavelength.
I think the only really simple relationship is that lower frequencies (longer wavelengths) diffract more easily, so they get around corners better. But reflection and transmittance, I don't think there's a simple model that defines them.
