My old dell precision 670 is giving me problems once again...so I just can't trust it for my freelance 3D work I do using 3ds max. I've already replaced the HDD (2 years ago), mother board and power supply, but I'm thinking its time for a change. It has dual xeon 3.6 CPUs, a Quadro fx 4400, which still work fine...the hard drive (I think) started going out so I went to my backup system.
I render using a 6 node render farm, so the workstation just has to handle the 3d work and some rendering, and video editing and encoding.
Is it possible to use some components off the workstation for a new workstation build or should I just put together something new from scratch? The old workstation power has been enough for me...still in 32 bit, which is fine...can a new WS build be about the same power as the dell for around $1K?
