Worklog Wooden Case
synxll
Hello, i'm building a new wood case, here the older I'm looking for a small case with good air cooling and silence
Size:
41,6 cm High = 16.38 inch
36,2 cm Depth = 14.25 inch
17,0 cm Width = 6.69 inch
It will support a maximum of 3 hard disks
Materials:
$ 32.50 MFD Wood of 9mm width (3.54 inch)
$ 03.20 Handle
$ 03.00 Self screws
$ 01.00 Hinges for the side door (2)
$ 02.80 Glue, to help on unions
$ 42.50 TOTAL = u$s 13.40 dollars
Hardware:
PSU HEC Orion 585 Watts
Gigabyte GA-MA69VM-S2
AMD 4000 Dualcore
2x1 Gb SuperTalent 800 cas4
160 Gb Sata 2 Hard Disk
DVDrw Pioneer
Accessories:
3 fans Evercool Red Scorpion of 14cm (5.51 inch) (67cfm at 22dba)
1 Fanbus Sumbeantech Lightbus for 4 fans
Here's the idea:
Some pictures of the wood i'll use, MDF of 9mm:
Another pictures of the case front
Photos of the support for the fanbus and DVDrw
That's all i've do today, i'll keep posting with updates. Bye
Hi, some pictures, of what i do today :D
Here the rack for the hdds, not complete yet:
Here, some pictures of the back of the case, where it fits the PSU
Here the screws unhidde
Here the screws hidden with Glue and Sawdust
Thats its all for today
Looking good, very hard to get a good finish on a wood case so put some time into it.
Yes, its required a lot of sanding for what i read :(
nice work.
Thanks man :D
ACTUALIZATION
Hi, i do that today:
Here the hinges:
The rack for the disks:
I leave the wood ready for embedding grids, so there are not any screws to see, then i've to put some glue with sandust to fill the holes:
Here, the system close for the lateral:
Here, pictures, cutting the lateral:
The case with the lateral ready to use:
I'll keep posting with updates
Looking great so far. Any idea on the color?
Thanks. Not think on that yet . I've to decide what color to use.
ACTUALIZATION:
The details of the cuts of the back ports:
Here a picture, with the weight of the case, 3.1kg:
Here pictures, with the sawdust with glue, that i used to hide all the screws
Tomorrow some sanding, sorry for post today what i do yesterday, but tonight when i going to post, they are heave storms, and disconnect the modem and router for safety
Do you have a belt sander to sand that wood/glue? It's going to be as hard as a rock.
What if you need to change the fan later on?
Hi, respect to the glue more sandust i used on the holes, its really hard. So i started sanding with this:
:eek::cool::D
That its an escofina, i dont know how it's said that word on english, but it has sand really easy the glue+sandust.
Respect to the fans, i can change without problems, because on the holes i did i put some the nuts for screws and after that i screwed the screws of the fan to the nuts. After that i put the glue and sandust on the holes, so from that way, i can unscrew the screws of the coolers, and even change the coolers :D
The English name for it is a rasp
Looks great so far. Nice build:D
Thanks man, it wasn't appear on google translation :p
Thanks, now i waiting my brother appear, he have an airbrush, i think the wood would see beter painted with the airbrush than with a brush.
Now, i'll research a little about painting mdf.
Today i;ve make the holes for usb, and power, reset buttons
Hello, yesterday i worked on the cuts fors USB and power buttons. Today, at 12am y painted the first hand of Synthetic Enamel white. I'll probably give 2 or 3 hands. I'll sand with 1000 grid between paintings.
Here the pictures of the firs hand
Hi, i painted the first hand at 12:00am, at 18:50 i sanded, first with 220 sand, and later 1000 grid sand. At 19:20 I finally apply the second hand of Synthetic Enamel white.
What you think about this combination of colors for the case?
Front yellow, Back white. sides black and yellow, with my nick on one side (the side of the door) writed on black. And upper, 3/4 yellow and 1/4 white. And al the fan grills black ?
Looking nice so far! Just be careful about those hinge screws in the MDF--MDF doesn't do real well with screws. It's worth putting a drop of glue in the hole for each screw so that it's harder for the screw to strip the wood or back out.
Hello, yea i put some glue on every screw for security, and also on the unions of the woods. Thanks
I finally buy the paint!!!!
I bought Ruster Oleum black and white, and Krylon yellow and red :D
Cost: the 4 by $72 pesos or u$s 22.65 or 14.20 Euros
And also buy sand of 400 and 1200 grid
Hello, today at 19hs, i pained with white painters touch all the case, internal and external, i'll keep painting tomorrow
Here a pic
Hello, i'm back :D.
Yesterday my syster printed the Moulds for painting over the case. Today, my syster help me to put the moulds all over the case, to start painting the yellows parts, here pictures of the proccess:
wow this case is looking great, so much planning is involved in measuring...its hardcore. congrats on being so intricate! i could never do this well!!
You are racist.
Lol jking
Nice dude. I wanna see the finished result!
Thanks man, now i'll put the templates to paint red :)
Really thanks :D
I almost finished, only left to paint red and black, and some details, install the front buttons and USB, and the case will be 100% finished :D
I put our the templates of the yellow paint, it's keep from this way:
Awesome job, I like the design templates...
Good planning, good workmanship, good painting... win in every-aspect :D
Thanks man, i try to do the best possible on this mod, the last mod wasn't good finish, so in this one, i try to do the best best possible finish.
Today i haven't time to paint the black part with the work, i'll try to do that tomorrow and post some pics :D
