[Worklog] Soberheid
Smasher
Well the idea of this project starts from finding a discarded case
on the street. Soberheid the name, saying that in order to
project will be a sober and elegant case. Leave the pictures of how it started
everything. After them speak for themselves.
So I found it in the trash …
Start smashing
So the components are located.
The materials for the housing and termination, wood, imitation leather and glue.
Cutting all woods, holes as well.
The work table ahah
The superstar modder (¿?)
Guidelines for the sides
And closing the top, all one piece.
Perfect
Well, as you go, I'll be leaving more photos. Greetings!
This is turning out far better than i thought it was honestly, Your skills are good!
I bring more progress here:
The liquid cooling block is a block that did a while back, a
block home that pays pretty well.
And some photos "pre-final"
Caution: The project is not complete. These are some photos of the preview.
It is not over!
As I will travel warning. I will not be for a few weeks and I'm not posting gains. Greetingsto everyone and when the project ended again!
Wow great build, You really made something out of nothing. Your whole system is very DIY even liquid cooling. Did you make that cpu block?
Im also kinda interested how your gona do your DVD drive and harddrive solutions, kinda shot urself in foot with radiator mounting like that. But im sure you have it all planned out im just curious and want to see it finished.
Alright guys, after a while of being away from modding, we started again to finish the project.
This is gonna be a the right side for covering the mothertray.
And the sideway's with acrylic
The worklog continues down!
Making of the sideway's acrylics
And then… Paint it White!
The screws will hold the acrylic side
Painted power button
acrylic bonding
Lights!
Power off button.
Acrylic legs with leds
Alright, the Windows!
And little surprise that at last I'm going to say;)
Recording the name…
The project is now complete. When I have edited the final photos update the worklog.Along with the photos I will upload screen temperatures for asking!
Greetings and see you in the final pictures!
Ha, this is cool! I've never seen a 'leather' wrapped PC! Very unique! Great craftsmanship.
Well guys i edit before the final pics, an organization of the inside ~
Now yes i salute you and i be posting the final pics in the next days ;)
Soberheid becomes from Dutch, and it means sobriety. Is a case that was found on the streets (trash), broken, with the covers and veneers crooked and missing pieces, including the laterals. Already with the idea of sobriety, it was thought for being black and white, searching wich materials may be used (for avoid the ordinary plastic and veneer)arises the idea of making the structure practicly from the beginning, covered with black leatherette.
Like this, was made this cabinet that now it comes to be a piece with elegance and sobriety, counting with a united top and frontal sides and entirely smooth, with details like screws “allen head”. (holding the base wood and the guides of the lateral covers to the top veneer and original frontal)
This cabinet is divided in two parts, in the first part is situated the mother tray; with precision and exceptional perfection in the organization of the cables. In the second part, the frontal one, are situated in an “invisible” way the radiator of the liquid refrigeration, next to the bomb, the power supply and the hard disk.
There always are few questions like: “But if the air enters by the radiator, it doesn’t have enough space to come out”, “ Does the leatherette and the wood get heated?” The answer for this, it’s that the heated air that comes out from the other side of the radiator, is expelled by a fan of 12cm. The leatherette and the wood doesn’t get heated, the microprocessor’s temperatures are almost the same than an ordinary computer with a cooler stock.
“But there isn’t enough space for the air to come in to the fans” The lateral acrylics are separated by a distance of 10mm by screws and heat-shrink tubing of the lateral veneer, letting space between the lateral and the lower too, it’s got enough space for it to come in(left side) and to come out (right side).
For giving it a special touch of elegance, there were placed a few white led lights inside the cabinet and in the support. The switching on of this lights is something particular, it’s about a metal “button” placed in the front. This button belongs to a touch power circuit, just with a finger touch to this button, you can switch on or off the lights. Excepting the white light of the power button that it’s always on to know if the system is working or not.
“From the trash, to elegancy and sobriety” ​
Next, the expected final pictures:
& the Modder Superstar=)
Temperatures:
Mostly, what matters is not just the hardware; what really worth it is the work that is made with our time and patience to get what we want.​
Hope you like it… You can take a look and follow my other works in:
Facebook
BWModding
