AoL_Is_My_EnEmY
- Mar 19, 2002
Ok guys, I was bored today. So I decided to attempt my first mod ever, besides cold cathodes and LED Fans. I had an old Compaq 7000 series case lying around, so I said what the hell. This is what I have done so far for $9.57. I still have to put molding around the edges of the window, install the plexi, and put scupley around the front duct then add mesh behind it. The duct is really a funnel that I cut in half with a hand saw
Heres the original compaq case (not mine):
http://www.rhdata.dk/images/Presario 7000-172.jpg
Heres what I did:
^Front bezel and chassis of case^
^Case side door with window^
^Front Bezel^
^Front Bezel Again^
^Close up of case color and glossy finish^
^Molding and Nexus Fan Controller^
^Plexi for Window^
Well, I hope it wasn't bad for my first try. I'm going to put blue EL wire behind that see through blue plastic in front, 2 blue cold cathodes, and 2 blue LED fans. Also keep in mind, that I don't own a dremel, and I used a hand saw, saber saw, and sand paper to get all my edges/corners. Cutting was hard. Plus I suck at painting. But oh well, more will be up soon.
Heres what I did:
^Front Bezel^
^Front Bezel Again^
^Plexi for Window^
