[WORKLOG] Project mATX Ser.Nº005 Galletabah
galletabah
Hi, My name is Luis Saborido, alias 'Galletabah', I'm doing a new project log with a very exclusive custom case, The project mAtx:
Project mATX Artisan Page - ONE Case Left!
Only there are 25 units in the world!
The case only has 20 liters volumen and I will use acrylic (16/12), 3 radiators, gpu and cpu (x99) with waterblocks, ddc pump with top/res combo, aquaero 5LT and custom sleev.
The following companies are sponsoring my project:
- Alphacool
- Artic
- Cablemod
- Blacknoise
The pc specs:
- 5820k
- asrock x99m fatality killer
- gigabyte gtx 980
- 16gb ram ddr4 2133mhz
- ssd 120 ultra M.2
- 1 tb hdd 2.5" x2 units
- Silverstone sx600-G FanMod noctua & custom cables
Peripherals:
- logitech g502
- vortex pok3r LED mod
- BenQ XL2730Z
- Benq GL2460 (second)
- Asus xonar u7 echelon
- SuperLux HD681EVO
The provisional status of the equipment is this:
I will update the post as soon I progress in the project
Thanks!
Well, we start with the updates.
This time we will show all loan from Artic:
I have chosen not to use the second support arms because I didnt need all magnitude
Making thread in this piece, we can give less or more hardness to the monitor's arms to fall under its own weight, or up by the force of the piston:
Mounted monitors:
Preinstalled clips to route wires:
Arctic has also given us the already known thermal paste that perfomance so well:
If you want to buy this fantastic arm, you can find Here
Note that the left monitor has been replaced by a 24" benq monitor, which will be in next updates
see you soon!
WATCH OUT, HEAVY PICS!
Hello everybody!
2845731
Today we will see the rest of the material that manufacturers have sent us.
This begins with Blacknoise and the famous fans NB-eLoop B12-PS
The fans work sooo great, and have a spectacular design, They are very quiet and push a lot of aire.
In my case, having the fans in pull, the proximity to the grill generates a slight hiss noise that becomes relatively annoying, so I am forced to limit the 4 units that are near the grill at 1200 rpm.
2847611
2847612
2847613
2847614
2847615
2847616
2847617
2847618
2847619
2847620
2847621
2847622
2847623
Well, Now we will see the Alphacool material.
Alphacool has sent us practically all the watercooling. Also, they have sent me materials several times to complete the project. 10 for Alphacool!.
We start with the splitter:
The new Alphacool Eiszapfen fittings, nice quality, very good paint and a perfect sealed.
In this case I decided to use the 16/12 fittings.
Hardtube 16/13:
The used pump is the new Alphacool Laing DDC310, It has a pressure and a considerable water push with only 10W.
The top/res used is the little Eisdecke with around 100 ml. It has a nice quality and it's transparency is fine.
The radiators. I think they are the best prefomance/price radiators:
Remember, clean your radiator before use it!
Waterblocks!
The first waterblock I used has a leak and Alphacool sent me two new units to choose which one to use.
As i said before, a fabulous company.
I choose the full brass cpu waterblock because I think is the best for my setup, but i will use the phobya in a next project (yes, other ITX project!)
The screws are badly painted, but with a spray has been fixed:
The phobya waterblock:
The waterblock:
This one has decreased 4 degrees compared to the previous full cooper ekwb waterblook in the core. I can't see the VRM/Mem temp, but I think has a normal temp because the front/back planet isn't too hot.
All mounted (NO IS THE FINAL WATERBLOCK, WE WILL SEE IT IN THE NEXT UPDATES):
enough for today
Today I have shown all material. That means begin the project!
Best Regards!
Well, we started the party assembly.
We will not use spoilers today.
The naked case:
Hard drives behind the motherboard:
And now let the Fan Mod and vinyl:
Sensor on the heatsink of the psu to control the temps from AquaSuite.
We passed directly to the manufacture the pump bracket:
Boss supervision:
We have also fabricated a backplate to hide the wiring that will be used in the case. Because of the abundance of wiring I have decided to be as high as possible to give me much space as possible.
Leds, performing welding and test:
I hope you like the update today.
Currently they have jumped about 45% of the images. This week will finish the project.
Greetings and see you soon!
Reactions: Derf
Espera que carguen compi :)
A mí hay muchas que no me cargan. ¿Cómo sabes que soy español? Tu nick no me resulta familiar ;)
Many pictures do not seem to load on my end. How do you know I'm spanish? Your nick doesn't sound familiar to me.
Porque son excesivamente grandes, ábrelas en otra pestaña para visualizarlas
OPEN IT IN NEW TAB
Today I'll show you step by step the installation to the final result of my setup.
BUT BEFORE! the leak, guilty of change the waterblock:
First photos as I wire the setup and how I managed to order it. Significantly, it is a little ghetto.
Well, start with the installation (you'll notice that the cpu block is different in some picture,
it is because the I saw the leak in the first tests and used.
And now, after so much waiting, the setup is complete !!
I hope you like the end result.
I get up around 30 "Artistic" photos, but the important ones are up
