The pin here is missing on my XCLIO GOODPOWER 500W ATX 500W Power Supply 115/230 V UL, CUL, TUV, CB, VDE, FIMKO, DEMKO, NEMKO, SEMKO.
Edit. Actually, according to the picture on newegg it's not NOT there, this I'll now assume is normal. Phew. I thought I was going to have to go through the RMA experience.
Heres the picture from Newegg
Ok, got that out of the way.
Now, I'm curious. Heres my system real quick.
P5B Deluxe + Intel Core 2 Duo E6400
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
LITE-ON 16X DVD±R DVD Burner W/ 5X DVD-RAM Write Black ATAPI/E-IDE Model
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA
EVGA 7950GT
Now, I installed the motherboard into the case.
Installed the CPU and Stock HS (Was a pain the ass BTW)
I connected the 4 pin power connector to the 4 pin CPU power socket
I installed my ram
I installed my GPU + PCIE power
Keyboard
ATX power of course
(Basically the basic stuff to get things going)
Ok, my concern is that it's not recieving enough power. This may be a false concern, brought about by the 24pin connector scare and my inexperience, or I might have a issue with the PC. When I first powered on, it seemed to start up slow, about 3 or 4 seconds, are CD2's slow and quiet accelerators? This may be my imagination trying to tell me I have trouble, or this is just the way pentiums are. I dont know, I have never had a pentium before. I'm used to the PC powering on coupled with noise of activity, ie a fast fan and my monitor pinging about a second to a second and a half later. The PC I'm used to is a 3200 AMD64. Are AMD64's generally louder than the C2d's? I'm also thinking that it's possibly the fact that I only have the base compenents connected so the CPU is conserving power. How does that sound? I thought I would ask before I tried. Looking forward to replies. Hopefully I can get it all set up tonight!
