Work Unit Not Sending
Status
Not open for further replies.
clean_me
As the title says, it won't upload. Here's the log after I restarted the client:
Code:
[15:21:56] Loaded queue successfully.
[15:21:56] Deleting incompletely fetched item (4) from queue position #5
[15:21:56] - Warning: Could not delete all work unit files (5): Core file absent
[15:21:56] - Preparing to get new work unit...
[15:21:56] - Autosending finished units...
[15:21:56] + Attempting to get work packet
[15:21:56] Trying to send all finished work units
[15:21:56] - Will indicate memory of 10200 MB
[15:21:56] - Connecting to assignment server
[15:21:56] Connecting to http://assign.stanford.edu:8080/
[15:21:56] + Attempting to send results
[15:21:56] - Reading file work/wuresults_04.dat from core
[15:21:56]   (Read 14764116 bytes from disk)
[15:21:56] Connecting to http://171.64.65.63:8080/
[15:23:11] - Couldn't send HTTP request to server
[15:23:11] + Could not connect to Assignment Server
[15:23:11] Connecting to http://assign2.stanford.edu:80/
[15:23:11] + Could not connect to Work Server (results)
[15:23:11]     (171.64.65.63:8080)
[15:23:11] - Error: Could not transmit unit 04 (completed May 8) to work server.
[15:23:11] - 5 failed uploads of this unit.
[15:23:11] + Attempting to send results
[15:23:11] - Reading file work/wuresults_04.dat from core
[15:23:11]   (Read 14764116 bytes from disk)
[15:23:11] Connecting to http://171.65.103.100:8080/
[15:24:26] - Couldn't send HTTP request to server
[15:24:26] + Could not connect to Assignment Server 2
[15:24:26] + Could not connect to Work Server (results)
[15:24:26] + Couldn't get work instructions.
[15:24:26]     (171.65.103.100:8080)
[15:24:26] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[15:24:26]   Could not transmit unit 04 to Collection server; keeping in queue.
[15:24:26] + Sent 0 of 1 completed units to the server
[15:24:26] - Autosend completed
[15:24:40] + Attempting to get work packet
[15:24:40] - Will indicate memory of 10200 MB
[15:24:40] - Connecting to assignment server
[15:24:40] Connecting to http://assign.stanford.edu:8080/
[15:25:55] - Couldn't send HTTP request to server
[15:25:55] + Could not connect to Assignment Server
[15:25:55] Connecting to http://assign2.stanford.edu:80/
[15:27:10] - Couldn't send HTTP request to server
[15:27:10] + Could not connect to Assignment Server 2
[15:27:10] + Couldn't get work instructions.
[15:27:10] - Error: Attempt #2  to get work failed, and no other work to do.
[15:27:25] + Attempting to get work packet
[15:27:25] - Will indicate memory of 10200 MB
[15:27:25] - Connecting to assignment server
[15:27:25] Connecting to http://assign.stanford.edu:8080/
Any idea what to do?
Well, in this case, the best thing is to reboot the computer then before restarting normally, go in the command line and go to the folding folder. In there, type fah -queueinfo to read the details. If you see a line with DONE, it mean this is the WU we are trying to send. Mark the line number then type fah -send # to force it to send the WU manually.
Also, make sure you did configure the internet connection properly in FAH and make sure you can connect to the internet.
I had that same problem with a few of my computers. I had to change my port from 8080 to 80 and change my usereg to no....
Status
