Started doing some research for a work rig, and figured I'd get some more feedback and thoughts for a non-gaming machine. I'm still doing my research, but this may help shave some time off before reading every review of every chipset to get myself back "up to speed" on things.
For those who think that a dev machine needs to be some slow rig, try waiting 10-20 minutes between builds on a "corporate PC (I5-8gb-single HDD)" - and please, no debate on whos app takes whatever time to compile.
There are multiple projects (8) which can be built in parallel, and most dev is in ASM/C/C++/c#. Using VS2005/2010 (migration).
Graphics card should be half decent to take advantage of WPF in vs2010 for vizs, but not some uber game card that does 1 billion FPS. I'm not railing bugs, just stepping through them.
Major thing is that it must be quiet when tucked under a desk. Big 200 fans at lower speeds do a great job versus the 80-120 fans that move air, and sound like a small turbo spooled up.
Development / VMs / Debugging possibly with 3D apps from time to time.
~$1700, yes
Florida, Jacksonville
-Case - Smaller quiet case with no "bling" lights - Corsair 600T, maybe cut the LEDs in the fans.
-MOBO - Intel DX79SI
-CPU - 3930K for multicore building of packages in parallel.
-CPU cooler - I've seen a few places where the NH-D14 works well, but unsure on this one. Or alternatively the Corsair H100 but both of them would be for making sure it was rock solid stable at say 4 Ghz. For stock or lower, both would be overkill.
-GPU - Ti 560
-PSU - 800 Watt, whothehellknows PS - possibly Corsair TX850
-SSD - Revodrive 3 x2 240GB - (critical part)
-COOLING - not completely sure here, but it must be QUIET!
RAM = 2x 8GB Patriot Sector 5 (4x 4GB modules - PC3-10666/1333Mhz - PGV38G1333ELK) - Had it already, but could get higher if it really made that much of a difference.
6) Will you be overclocking?
Slightly, but most likely not going to push over 4Ghz. Stability is crucial.
Dual 24" 1920x1080 at work or Dual 30" Dell 2560x1600 at home - Possibly considering the 28" monitors (2560x1440) for the real estate to replace the work ones.
Either way I'd like to make sure both ports are Dual-link DVI (from what I remember, this rules ATI out, or did at one point unless they finally took care of this oversight)
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0 (and on the case)
Nice to have:
SATA 6GB
ESATA
UEFI
1394/Firewire for possible Kernel Debugging (never know when I might need to) (on case be nice as well)
Dont need/care:
Crossfire/SLI
Onboard video
Yes, Win 7 x64 Pro
11) What do you need for a case?
Smaller, quiet, yet keeps board/cpu/mem/vid cool. Prefer to have USB 3.0 on the case. Nice to have 1394 (but not essential). No need for lights or anything fancy, black is best as it will be out of sight.
Since i'm looking to boot off of a Revodrive, the sata doesnt matter as much. If I decide to add 3 or 5 hard drives for larger storage (remember this is a work rig on a network), I have a raid card that pushes decent numbers on my other VM box (Perc-5i with 256meg pins 5/6 cut for SMB compatibility and reflashed to LSI) since Intel raids LOVE to rebuild themselves when nothing happens (unless they fixed that from the X58 boards).
I wouldnt mind pushing the CPU to 3.6, or a little more, but stability is the big thing, and it will most likely be sitting idle a bit of the time, except when I am building, of which I may do 10 builds a day (some incremental, some full, depends if VS is being stupid or not), so cutting this down is a big factor to me as its lost productivity time. Thus... overclocking is not critical.
So basically its CPU, Memory and Disk critical, and must be very quiet.
Thanks, and look forward to the feedback.
~$1700, yes
-GPU - Ti 560
Now
Nice to have:
SATA 6GB
ESATA
UEFI
Dont need/care:
Crossfire/SLI
Onboard video
Yes, Win 7 x64 Pro
