mobilecommand
- Mar 22, 2005
I know this is a tad late...
The best tool to get around security on a box is help..
If you go to a locked down box and they still have help enabled you and do a search for almost anything and it usually gives you the ex: "Open -> Command Prompt" with the link that will open the utility 99 percent of the time..
So you can get user manager, command prompt, display settings etc..
Usually its enough to really pi$$ someone off or get you access to get a util on the HD to get what you need..
