wooh, another temp thread.... 2.8c @ 3.5Ghz
phatmonky
Perhaps this will give others some idea of what to expect in the future, and any comments are welcome :)
The basic setup is:
2.8c @ 3.5Ghz
ABIT IC7
2x256 Geil platinum pc4000
Offbrand case - Two exhaust, one intake.
I am in a room with A/C set to about 75F
I have managed stock voltage so far :D and things are running solid still. Farcry plays like a champ, and stress testing shows no stability problems.
My ABIT windows program says 31.0 SYS, 48.0 CPU, 32.0 PWM at idle
Running two copies of Folding@home, I get 32.0 SYS, 61.0 CPU 42.0 PWM
I am running some offbrand copper heatsink that my housemate gave to me. It has a ridiculous fan on it (in the neighborhood of 6800RPM's max). I have plans to order a thermaltake tonight.
Now, I understand the ABIT temps read high in the BIOS, but I find that the windows program, at idle, is running about 5-7C lower than my bios numbers. Could the windows program actually be figuring in math to give an accurate reading, instead of reading high?
everything I've seen shows it to still be too high.
I'm getting 33* in the case with 51* no load on my 3ghz at 3.3 on a zalman.
Room temp is 74ish*F ~23*C so I think its a tad off.
there is a big thread on abit's forums about the ic7 temps being off... i think its under the Max motherboards section.
