cupholder2.0
- Mar 30, 2006
InorganicMatter said:They've had the processors and memory for forever. It's the motherboards we are waiting on.
pxc said:Ouch, $761 for the 2.66GHz OEM version (10K tray pricing is $690).
Not a bad price for a dual Dempsey/Woodcrest server board ($349.99): http://www.newegg.com/Product/Product.asp?Item=N82E16813151161
Intel must stand behind every product with one of its chips in it!!!!!1ponePoncho said:Yea, that's the "value server" line and it's a Tyan board... yea, PASS!!@!@!.![]()
pxc said:Intel must stand behind every product with one of its chips in it!!!!!1pone
Yeaaaaa, we're going to need you to do some Tyan technical support tonight. And tomorrow. Yeah.
Better since they have a higher FSB.newls1 said:MHz to MHz are they the same performance to a conroe?
chrisf6969 said:2 of these: http://www.newegg.com/Product/Product.asp?Item=N82E16819117085 @ $390 = $780
+ $390 motherboard + FB Dimms. Still cheaper than an XE + mobo + ram.
And you'll have 4 cores. That would be a serious work horse machine if you do some type of encoding that could actually use all of that CPU power.
chrisf6969 said:And you'll have 4 cores. That would be a serious work horse machine if you do some type of encoding that could actually use all of that CPU power.
huh? I think you're reading the benchmarks wrong. The fastest dual core chip in that test is 2.2GHz (275). The slowest single core Opteron tested was 2.2GHz (248). You would compare 4x2.2GHz cores against 2x2.2GHz cores since many of the apps clearly don't scale by n threads. In every case 4x2.2GHz beats 2x2.2GHz.KCComp said:Alias Maya 6.0 (1 version back)
Photoshop CS (1 version back)
Macromedia Flash MX 2004 (at least 1 version back)
Microsoft Windows Media Encoder 9.0 (still current)
LAME 3.97 (3.98 relnotes don't mention threading fixes)
Sciencemark 2.0 (still current)
Half-Life 2
DOOM 3
That would be greeeat.pxc said:Intel must stand behind every product with one of its chips in it!!!!!1pone
