Won't turn on
OK, I'm pretty good at troubleshooting these things, but I'm stuck with a Gigabyte K8U-939 board and a 3800 X2 that just ain't happening. Initially, the machine would turn on but not post. Now it has the intermittent power on syndrome. Push button, fans spin for a second, turns off. I've taken the board out of the case and reduced the connections to just the power switch, mem and video card; held it away from anything that might be shorting. It simply won't stay on. I've had this happen occasionally with other builds, but I was always able to jiggle something to get it going. Not this time. Suggestions? Thanks...
Dennis Gordon, your motherboard needs BIOS revision F2 installed for X2 CPU support, rather than the initial release version F1. Are you sure it's been installed?
