I built a new system back in August with the below parts. It has ran flawlessly since then. I woke up in the morning to find the system dead. I had left it on over night but then it was off. And wont start up.
The lights on the motherboard do turn on when power is applied. The very first time after power is applied (plug in or switch on psu), and only the first time, when you hit the main power switch you will hear an audible click and you can see all of the fans move. But just barely. The machine does not actually turn on. And it only does that the first time. It will not click again unless power is completely cut. As if a breaker is being tripped and wont turn on again until its reset.
Any ideas on what this might be? I already swapped out the power supply with another know good unit. And that was not the problem.
Asus X99 Deluxe
I7 5820k
LEPA watercooler
Asus strix 970
Gskill 2400 4x4gb
Asus X99 Deluxe
I7 5820k
LEPA watercooler
Asus strix 970
Gskill 2400 4x4gb
