Wheresatom
- Mar 20, 2007
I have an Asus P5N-E SLI MB that had 2 gigs of G.Skill RAM and an Intel E 6420 processor. I plan on upgrading to Vista from XP-64 bit pretty soon. I want to go with the 64 bit Vista so I decided I should go ahead and look for RAM so I can take advantage of the 64 bit part. I found the exact same RAM and bought it.
When I went to install it, the computer would not start. I started trying different combos and I think I have figured out the problem is not with the RAM. Both sticks work on either open slot one at at time. If both are installed the computer will not even get to the BIOS. Whats wrong here? Do I need to flash the bios or something? Or is there just a setting I can change and everything will be fine?
