Won't post....sometimes...
legcramp
Specs in my sig... I ahve a gigabyte k8n pro mobo with dual bios.. anyways.... sometimes it wont post.. but there is just a beep beep beep beep and it goes on forever... the hard drive lights blink along with the beeps.. and after each beep.. it seems to try and read from the cd rom drive.... today i booted up jsut fine.. it posted and everything... but this happens randomly... I tried clearing cmos and everything,,, switch out psu and same thing... this is with award bios btw.... and I switch out ram too... no luck... sometimes it just wont post.. AND
I get random reboots also.. last night it rebooted and I couldn't post anymore.. today it works....any help?
only time i have encountered anything like that was on a DFi-lp ultra d , it was finally traced down to a lose connection on one of the sata drives . :eek:
Remove everything but the CPU and the RAM. If it posts consistently, add a hard drive, then test it, then add your other devices, one by one. If it destabilizes on any step, you know which component to blame.
If it doesn't work with just the CPU and RAM, try a different stick of memory, and try different slots.
A
