wont boot up after bios update, a8n32 Please Help
snipes23
Tried to update bios for my asus a8n32 with the flash program it came with, updated from file that I downloaded from asus site. I installed it, and after it was done it had to reboot. Well it restarted, but all I get is a blank screen and the vid cards fan just keeps on blowing air, doesn't stop like after a few seconds like it usually does.
I turned the system off, took the cmos battery out, and moved the jumper to clear it, then put the jumpers back to default, installed the battery , plugged power cord back in, turned on, and same things. The vid card fan just keeps on blowing hard and it doesn't go to the boot up screen or anything. The fans light up, and so does the kb.
If anyone has any ideas I would gladly appreciate them.
Thanks, Mike
sounds like your bios update might not have gone as well as planned. they can send you a new bios chip but you have to call tech support and have them walk you through a few troubleshooting steps.
