hopefullyChernobyl1 said:excellent.
Hopefully the Witch hunt will stop now
Theyre coming in a few days and Ill definitely post what happens
It's good that they're sending you parts so you can start shotgunning at the fix. Hopefully, the issue doesn't turn out to be with a part they're not sending in this first batch.jcll2002 said:anyway, I called monarch where they built my rig and they said that there was an earlier problem with the PSUs and theyre coming to fix it because theyve had alot of calls like this. Theyre also sending a motherboard just incase.
Glad you got it working. What failed on the mobo, and what caused the failure?jcll2002 said:it was the MOBO.
