jonathonball
- Sep 23, 2005
I'm having issues during start-up of my latest PC build.
First thing: this PC works! Just having some weirdness on startup. Once started it does not have performance issues. I have been able to get it to start each day, after some trouble.
Here's the system in question:
Each morning when I go to power on:
If there is any other related info I can provide, please let me know. I'm at a loss here.
- ASUS TUF Z490 Gaming /w WIFI
- Intel Core i9 10900K
- Corsair Vengeance RGB Pro 64GB (4 x16GB) DDR4 3200
- Intel 665p series M.2 2280 2TB NVMe SSD
- eVGA GeForce RTX 2080 XC Black
- Corsair HX1200i PSU
- Corsair iCUE HT150i RGB PRO XT
- Corsair Obsidian 750d case
- Win 10 Pro
- CPU: 35c idle / 70 max
- GPU: 55c idle / 78 max
- 3D Mark Time Spy 1.2 Score: 10584
- https://www.userbenchmark.com/UserRun/34929430
- I push the power button and it does nothing,
- I push the power button again and I can hear the CPU cooler pump start up, then the fans on the radiator engage and then throttle up and it will stay stuck like this. No activity on the motherboard, change in LEDs, no other signs the system is powered on.
- If I push the power button again it does nothing. I have to either hold power for 5 seconds or flip the power switch on the PSU.
- After a few attempts the behavior changes. It will get a little further and LEDs on various components will start to flicker and then it will power off.
- After a few more power on attempts; it will finally power on, normally.
- Whole process takes between 2 and 20 minutes. I have been able to get it to start every day, after some trouble.
- The steps and behavior are a little different each day, but generally go like this.
- Removed RGB LED strips
- Temporarily replaced mobo front panel connectors with a third party one (https://www.amazon.com/gp/product/B074891DJP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) that I had on hand.
- Removing wall power completely for 20 minutes
- Shorted the CMOS reset pins and reconfigured the motherboard
- Tried using the reset button to recycle the system when its stuck starting up.
