Won a PSP - what do I do now?
Anything newer than 2.8 and you are screwed.
No, anything under 3.03 can be downgraded. But for 2.8-3.03 you need an unpatched copy of GTA:LCS. There is no way to downgrade anything above 3.03 yet.
Yah there is, but you have to pay $60 for this (click PSP Undiluted Platinum (U.P.) PSP Mod Chip won't direct link) , open up the PSP and do some soldering. They have the set-up to do any firmware on mobo's TA-079 and TA-081 and they HAD info on their site saying they were about to release one that would do mobo TA-082, but now it seems they pulled all that off and are saying
PSP consoles with a TA-082 are not supported, however, they seem to be limited to Asia and have 2.6 or above firmwares. We believe that overall numbers of TA-082 as a proportion compared with TA-079, and TA-081, should be quite limited.
Check to make sure you dont have TA-082 Motherboard without voiding your warranty!
Which isn't exactly true, because my USA bought PSP has a TA-082 mobo and I know many people that have the same (although I do live in Hawaii and that is kinda like Asia lol).
That is interesting.
Mine is also a TA-082 and it came with fw 2.60. Its not US though; White Japanese flavor.
The list of the firmwares that someone posted earlier is also wrong, as my psp is a PSP-1000 F.
According to that chart it should of came with 2.0, which it did not. (2.60)
There's your answer.
Well I just downgraded my PSP to 1.5 then upgraded to 3.03 OE-C.
Working very, very well. But 2Gbs is not enough...when well you have 700Mbs ISOs of well..yeah =P
I'm very impressed with the PSP....very awesome device :)
You can easily compress most of the ISOs, it should save you some space. Go download UMDGen first. You can use it rip out the update folder that many games come with, then you can compress it to CSO file. It works amazing for some games (800mb to 80mb for example), but for most games, it compress to 70-80% of the original's size.
Not sure how you read the "version" letter, but if you read it as "PSP-1000 F" as you wrote, then you are using the wrong letter. Check out the pic below. You want the letter directly under the "V" in 120V. Not the letter following PSP-1XXX
Mine was a K on the box, which the chart said should be a 2.71 FW and it was correct.
Using UMDGen can you remove music and video tracks? Is it as easy as just deleting them or do you need to create dummy files?
Update:
Awesome...I was able to take Test Drive Unlimited from the original 1422mb, down to 940mb by converting it to a CSO, then down to 640mb by removing the music and video. Great success.
Yes, I do own the game.
You can remove the music but videos I think you need to relink them. Most of the time I only remove the update folder and extra languages. Although sometimes removing the music is necessary, ie. Burnout Dominator...Avril Lavigne? No thanks.
I didn't relink anything, I just removed the files but left the folders. What would you have to relink the files to? What problems may I have by just deleting the files.
Woohoo! A little OT but I didn't want to start a new topic, but Killzone Liberation's infrastructure patch finally came out! Damn, after 8 months of waiting it finally came out. I've been playing the whole morning in class, this game is damn fun online.
May I ask why you went for 3.03OE-C instead of 3.40OE-A?
lol the guide I was following said that was the latest version...Oh well its working mighty fine for me :)
Thanks for that man, I was able to cut a good 200Mbs from a couple of ISOs :)
Can someone explain what "devhook" is and what it's purpose is? Would I need it if I just wanted to run emulators and customize my XMB?
Devhook is basically just an alternative way to play your ISO files. It emulates the latest firmware from Sony and acts sort of as a virtual drive for your PSP. It was the preferred program to play your game backups before custom firmware came onto the scene. Nowadays, custom firmware lets you play emulators, backup ISOs, customized XMB, etc.
Well, to answer your question - no, devhook has nothing to do with emulators or customizing XMB.
homebrew is so easy its not even funny and modding your psp is as easy as 1-2-3 and the chances of you bricking your psp nowadays is slim with the mods being used today.
First you can modify any psp up to 3.03 firmware. Anything over than that and you are screwed. I've modified so many psp's and what I would do is update it to 3.3 firmware then use a simple file (3.03EASYDOWN) ( from psp-hacks.com to revert it back to 1.5 then used one of dark alex's amazing modded firmware (I think the latest is 3.40OEAa) and wala.....now you can play any ISO games as well as ps1 games.
How can you tell if your copy of GTA:LCS is patched? Just bought an old, used copy from GS and it has a brown background and gun on the UMD disc. Too bad my PSP doesn't come in until Weds to see if it has the 2.0 updater on it.
Put the game in the psp. Scroll over to the game's UMD update (looks like a UMD icon with arrows in a circle) and if it says "PSP Update ver 2.00" then it is the unpatched game. If it is anything else, it's not what you want. Seeing what it is without doing this, I am not sure. Right now I am borrowing a firends GTA:LCS and it is the unpatched version and has a brown background with a gun on it (also a hand holding the gun). I went to gamestops and ebgames trying to get my own UMD of this game and found one Ebgame that had what I thought was it. Went to buy it and the manager pretty much pegged me for what I was wanting and told me "the original has a guy on it" and I walked out without buying the game. Then I after I left, I started thinking he was BSing me and now that I see my friend GTA:LCS, I am pretty sure he was, because the UMD at the store looks exactly like my friends and I know my friends is a 2.00 . No matter. After I downgrade this PSP with the borrowed GTA game, I won't need it anymore. Not planning to make a carreer out of it.
This thread makes me want to go out and get me a PSP.... To bad I just broke my bank getting a PS3 + 4 controllers + HDTV + 7.2 megapixel digi....
I can't wait to get a PSP now ;)
Try getting engaged two months ago, having a ring payment, apartment rent, cell phone bill, credit card bill and a piss poor job on top. But I sold/traded a few PC parts to get my PSP from an old online buddy.
Agreed. For now, I'd go with a 4GB since they can be had for $50 new from a respectable site (do not buy them from ebay as they are usually fake!).
v2.71 can easily be downgraded so that is great news for you. Once downgraded, you can update to Dark Alex's custom firmware - 3.40OE-A (read: never update to an official Sony firmware).
Downgrading guide: Link
Updating guide to 3.40OE-A: Link
Ok, I have tried using the downgrade guide listed here with no luck, I have a 2.80 with no indicators on my motherboard. Anything else I can try, maybe something with my original GTA LS UMD?
I bought my unpatched GTA:LCS of a fellow Hardforum member for $15shipped, this was shortly after the FW2.80-3.03 exploit was found. I guess I was lucky. If anybody is around Sterling Heights, MI, I'll gladly downgrade them to FW1.50.
outside of roms and "legal backups" :rolleyes: what else does homebrew offer for the psp?
Playing backups is one of my favorite features about Homebrew. I don't need to carry all my UMD's, I can have many full games on my PSP at all times. I admitt, I've downloaded PSP games before. Take for example Test Drive Unlimited, I downloaded the Euro promo and played that for a few months, waiting for it to be released in the States. The day that TDU was available in the stores, I went out and bought it. But a few days after that I downloaded the USA ISO so I could have it on my PSP along with a few other games.
The only games I have that are illegal are ones that are not available in the United States, and try as I might I cannot find them for sale on any of the import sites (Pilot Academy). Here are all the games I have on my PSP right now...
Gran Turismo 2 Simulation Disc (PSX)
Pilot Academy
Race Driver 2006
Mercury
Lumines
I have 12+ purchased PSP games, I think I'm doing my part in contributing to the PSP.
I just got Pimpstreamer on my PSP and although it is still a bit buggy on a 3.40 OE-A, it works decently enough. With that, I can watch every AVI movie/shows on my desktop via my PSP and a wifi connection from where ever. I am pretty impressed, the video quality is great and with a good connection it's very smooth. I can also play some WMV's, but not very well unless it's a very small wmv file. Just got that application last night and still messing around with it. Lot's of other things, but I am just getting into it myself. So far am very happy I got a PSP and went homebrew.
Just some off the top of my head, or some homebrew apps/funcions I use anyways.
Internet radio
Customizing your PSP's XMB
Wirelessly stream media
User developed games
Full resolution videos (although not anymore, Sony FW can do it now too)
TI calculator emulators (useful...these calculators are expensive :p)
Map applications that can be used with GPS add-on
Well, it sure as hell took awhile but I am now at 3.40 OE-A. Now I just need to do some looking around to get some homebrew. The guys at qj.net are awesome with answers.
Just got my PSP today and I installed 3.04OE-A. However, I can't get SNES9X to work. I put the 1.0 contents into psp/games, it starts to run but comes back to an error saying that it can't play the game. Any suggestions?
