Hey guys, been thinking of ditching wmp lately, and I know that there are a bunch of alternatives, but are there any that can actually play streams of the type of media that WMP does, especially .wmv?
If you have WMP core installed (default) then any player should play wmv. If you removed WMP completely (through nLite or something similar) then mplayer comes with its own wmv codecs and can still play wmv.
I've been using CCCP for a couple years now and havn't had any files I couldn't play. I opt for Media Player Classic and remove Zoom Player in the installation process.
My vote is completely for Media Player Classic - I never even considered it before. I much prefer it to VLC, WMP, and I use it to play all media files (I use Winamp only for music/video library and for the ipod, it's not the default player).
After I had MPC, I then installed Real Alternative and Quicktime Alternative. In the install for both of them select "Install Media Player Classic" even though you already have it. If I ever come across a file I can't play with MPC I will hunt down the codec.
It's great for DVD play as well, I don't know why but if has a better picture than VLC and WMP but I didn't bother fumbling around the options to find out why. It's a very stable player, very clean, to the point, and very comfortable. I always used VLC but I'm glad I've switched, no complaints here.
Seconded for MPC. I've tried VLC in the past, and it's nice, but MPC just smokes it for sheer features in my book, which would take a few hundred pages to explain all that MPC can do in a single tight .exe file. Nothing else even comes close...
Alright, media player classic seems like the way to go. RocketFast321 why would you get both core media player and mpc, is there something one can do that the other one can't? Or are you saying that those 2 are your favorites?
