WMP 11 wont stop playing
sanitarium16
My Windows Media Player wont stop playing after i close it in Vista. It keeps playing the sound. I have a logitech G15 gaming keyboard i think i remember something about this causing it but i dont remember. How do i fix this?
WMP11 sometimes doesn't really quit when you close out of it. Just kill the "wmplayer.exe" process in Task Manager.
I also have the G15 keyboard, but I've never heard of a connection between the two...
There is a fix for this, i just forgot it, i know it has something to do with the G15.... gotta seach then...damn vista
Probably a codec problem playing some media file(s). Or try turning off WMP Slideshow plugin or logitech media display.
I've had that happen to me several times, and I'm not using a G15 keyboard, or any Logitech keyboard.
