WMC Remotes
1911Shootist
What remote are you using?
I've been using a Hauppauge remote that plugged into my tuner card for years, but recently switched to HDHR Connect network tuner, so now I'm on the hunt for a new remote.
I hate remotes with a million buttons, and layouts with the number keys up top (prefer not to have them at all), or ones that look like they were designed for a preschooler.
I really wanted to like the Rii i25/K25 mini, but can't get the IR buttons to learn from my TV remote (I've tried two of the Rii's, both with the same issue). The RF keys will need remapping to be similar to the WMC functions I'm used to - a minor inconvenience.
Any other recommendations to check out?
