Subzerok11
- Aug 13, 2014
I've had this problem since 2011 but I lived with it. So every once in a while I'll insert a USB stick and it locks up the PC. By the way it's not the same USB stick either that causes it, it would happen to other sticks I have too. By the way it wouldn't lockup the PC every time but it would lock up the PC at least 1 in 5 times I'd say.
Also problem was happening while I had a 4.5GHz in place but never thought it was causing the problem so I never gave it any thought and just lived with this problem since 2011. So for fun I removed the OC recently and put everything back to stock factory settings. The problem has not returned once in the past few weeks. When I originally OC'ed my CPU I tested with prime and past a 1 hour test. Is it possible that my motherboard is cheap or it just didn't like being OC'ed ? and no this is not a troll topic.
