Witch power supply should i get?? HELP
I was thinking about getting the ENERMAX Galaxy EVO 1250W for my sig rig as I had the Galaxy 1000 in my last main rig as was a little worried that the 920 @ 4Ghz and 3 280s would push it but its working splendidly. I also have a 4 year old 660W Enermax in a another rig that still humming along nicely. So I'd go with the Enermax.
But unless you are running dual CPU's or something esoteric even the 1000 Galaxy will power something like me sig rig no sweat.
i have a core i7 975 5970 crosfire. 12 1T HITACHI drives and wd 10k 150gb drive. +watercooling, 10+ fans
Haha.. What do you think about the antec? The antec seems newer and more solid although one big negative about the antec is capacitors in the cables. Makes the not only bulky but unreliable if one goes bad.
The Antec performs well but is noisy and not practical. The Enermax would be easier to work with and also has a 120mm fan so it will produce much less noise.
