Wiring question
thebliX
When your cleaning up your wires, and you have a videocard like, radeon 9800pro, where do you hide the extra power cable?
i dont have a card that needs power, but i think people pull the wire to the MB then find a way to get it under or just run it straight up
I have the same problem as you, right now I have it running down the rear edge of the case (taped) and then out to the vid card from underneath. I imagine some paperclips, electrical tape, and some fancy bending could make it run right slong the edge of the card... :)
I bought a short power cable that converts 4-pin molex to floppy since right above the AGP slot I have a power connector on the mobo. Then I just plug it in and it goes underneath the card then right up into the connector. Barely visible
what i did was make a longer wire all together and wrapped it in that snake skin stuff, then ran it to the back of the mobo and plugged it in, never have used the fan that i was going to though.
here are some older pics................
[]http://www.iupload.net/012004/IMG_0791.JPG[/IMG]
http://www.iupload.net/012004/IMG_0829 L.JPG[/IMG]
nice
