I have the storm sniper which has a dial on the top to change fan speed and a button in the middle of this switch which turns the LED's on the 200mm fans on and off.
I'm not using any of the LED controllable fans in this case, switching to RPM controlled 120mm fans instead (I will be using 120mm radiators).
Basically, I want to rewire this thing so that the button will turn on and off the CCFL's instead.
I've taken a few pictures of everything which I hope will explain everything a little better:
Here is the PSU power, fan power/RPM controller and the red and black wires are for the fans LED's
I need to attach to this the CCFL board that attaches to the CCFL tubes:
This is how it is regularly wired, I want to use the case's LED switch (top picture) instead of the switch here:
The manual, just in case you wanted to see it:
How should I wire this up? Could someone draw me a diagram?
I need to know if I need to buy certain plugs or wiring and how to do it.
I am not very knowledgeable when it comes to wiring things, it does sound simple, but I might be thinking to hard.
Thanks
Thanks
