Wireless signal extender?
ssnyder28
Hello,
I need some help as I'm trying to find a way to make my wireless signal stronger, or at least make it so I can have multiple points in the house that are separate wireless connections. I'm sorry if I'm miswording any of this but can't you buy wireless hubs that would take the wireless signal and rebroadcast it?
I will warn you now that signal extenders while they do exist they are all crap and will half the speed of wifi and are a real bad solution. Look into a Access point instead and run a cable from the access point back to your router.
